Display driver not working in Dell Vostro n-series.
Asked By 35 points N/A Posted on -
Using Dell Vostro 1015 n-series containing Intel 45 express chip set graphics driver. When I start chrome browser it shows error “display driver stopped working”. I have uninstalled the driver and installed them again but the problem is still the same. Don’t know how to fix this. Suggest some way to solve this issue.
Best Answer by
Answered By points N/A #184148
Display drivers are for making the display adapter work perfectly. The problem you’re facing is either for corrupted driver or installation or installing the wrong driver.
First, make sure to have the correct driver for your device. According to Dell, this one is the latest driver for your system. Download the driver, uninstall the older one and install the latest driver.
Also, update your Google Chrome. In some case, there might be a bug that is generating this issue. Download Chrome.
If still no solution, you should try disabling “hardware acceleration”.
1. Open a new tab and go to “chrome://settings/”.
2. Scroll down and select “Show advanced settings”.
3. Under “System” section, uncheck “Use hardware acceleration when available”.
Answered By 590495 points N/A #184149
If you are using the Google Chrome web browser and it constantly prompts you of a display driver error, try updating your video driver. If this error prevents you from using Google Chrome, use Microsoft Internet Explorer then visit Intel Driver Update Utility Graphics. The page will automatically help you detect and install the latest driver for your graphics card.
To check your video card for the latest driver, click on the link “Check your system for updates”. See image.
If the utility requires you to install Java, download and install Java Runtime Environment 8.0 build 25. After installing the Java Runtime Environment, try starting Google Chrome again and see if the display driver error will appear. If the problem didn’t change, try installing the latest version of Google Chrome. Download and install Google Chrome for Windows.
