Disable one audion from the RMVB dual sound
Hi. I have been downloading rmvb files and I was not aware until I got to listen to it. It is actually an rmvb dual sound and I'm annoyed hearing two different sounds at the same time. Anyway to disable one audio while the other one is continuous playing? Thanks!
Answered By 5 points N/A #165741
Use Media Player Classic, you can download from this link: https://sourceforge.net/projects/guliverkli/ This software will let you to block out left or right channels. Go to the filter Audio Switcher and enable the Custom Channel mapping. Click or unclick the left or the right box, depends which you want to hear.
Also you can try convert the rmbv file to vcd with winavi. When converting is done, use the VirtualDub to full processing mode and use option for conversion for selecting the right or left channel to have just one audio. Then save as .avi and convert to dvd with winavi.
Williamson Mellisa
