DirectX9.0 is not installed or its version is not 9.0b
Hello all
I have recently installed silkroad online on my system but when I tried to run it, I was met with an error.
The screenshot of the error is attached below:
DirectX9.0 is not installed or its version is not 9.0b.nsilkroad online needs directX9.0b or later version.nWorld you move to the download page of directX9.0b
The error states:
Silkroad Online
“DirectX9.0 is not installed or its version is not 9.0b.nsilkroad online needs directX9.0b or later version.nWorld you move to the download page of directX9.0b?”
I don’t know what went wrong and where. Can anyone please advise me what should I do?
Your help will be appreciated.
Kindest regards.
Best Answer by Alcaraz Jody
Answered By 0 points N/A #197479
I will help you to install this app. It is clearing saying that, the software requires DirectX v9.0b or higher. You have either v8.0 or v9.0. So the application is asking you to go to the DirectX 9.0b download page. Go to there and install any version v9.0b or higher. The app will get installed.
Answered By 5 points N/A #142174
Dear Josiemelissaa,
Your software needs to be updated to the latest version so it stopped working, as mention above you can update it, But there is a smart trick to make it work correctly if you could not update it, you can change the date of your machine so it will work correctly as it was in the past.
