Hi
I am receiving this error when I am trying to utilize OWA on my Windows 7 pc (64bit) & (32bit):
"A digital ID that allows you to sign this message is missing."
A digital id that allow you to sign this message is missing. If your digital ID isn’t trusted by the exchange server, you can’t use it to sign message. Ask your server administrator to have the issuer of the digital ID trusted, or send the message without a digital signature. If you have a smart card-based digital ID, insert the card and try to send the message again.
What should I do now? Please help me.
To solve that problem you will need to do the following:
Carl
Please read the cause of the error for your better understanding.
1.If you do not have the certificate which should be matched to SMTP address
2. Active directory failed to publish certificate
Now, I am going for the solution:
1. Go to run, type mmc and hit enter
2. Click on file and then go to Add/Remove Snap-in
3. Now, Click add and then select certificate
4. Now go to my user account and finish it
5. Now click add computer account and next to finish it
6. Under current user, expand certificates. Right click on the intermediate certificate and go for the all tasks and import those certificates
Thanks for having your time
