Device manager not loading or blank
My old computer crashed because of a program that my brother installed. I tried to correct the problem by setting the computer to factory settings using a recovery disk. The computer is starting back but cannot connect to the internet using a dial-up connection.
Netscape support suggested that I update the modem driver and check for conflicts with other devices. Netscape support walked me through the steps to check the device manager, but it is not loading. The problem is that the device manager is blank. I restarted the computer multiple times with no luck. Does this means my computer is corrupted?
Other programs still runs okay. I have Windows XP.
Best Answer by JohnStewart
Answered By 0 points N/A #122143
Hello Bryan.
Try running SFC (System File Checker).  It is a Windows XP application that scans and (optionally) fixes Windows XP's system files.  If there are some system files that are corrupt (or even missing), System File Checker will replace it with a fresh copy.
Here is the procedure for running SFC (System File Checker).
1.  Open the Start Menu -> All Programs -> Accessories > highlight Command Prompt, right-click and press "Run as…"
2.  Choose "The following user", select Administrator and enter the administrator password.
3.  Within the command prompt window, type this:
sfc /scannow
4.  Wait until SFC process is complete.
5.  Reboot.
Your device manager window should now be back to normal.
Answered By 0 points N/A #122146
First try to restore your computer to earlier times. To do this point to All programs, Accessories, System tools, System restore. Run the wizard, select earlier on the calendar provide and restart the computer after finishing. If you had not set the monitoring please do so for it helps when minor problems occur.
If it doesn’t work, then set the startup type for Plug and Play to Automatic. To do so, follow these steps:
Click Start, click Run, type services.msc, and then click OK. Double-click Plug and Play.
If you receive a Configuration Manager message, click OK.
In the Startup Type list, click Automatic, and then click OK.
Close Services and restart the computer.
