Device manager doesn’t display some controllers..
Asked By 7060 points N/A Posted on -
Device manager is not displaying sound,audio and game controller..
why?
Please help.
Best Answer by Charlie Cloud
Answered By 0 points N/A #81893
Here is the solution to your problem :
Step 1: Go to Control Panel and then to Administrative Tools -> Services
Step 2: Go to "Windows Audio" service and open it
Step 3: If the Start-up type shows : "Disabled" or  "Manual", turn it to "Automatic" from the drop down menu and then click the "Start" Button
Step 4: Go to "Sound and Audio devices" in the "Control Panel" then select the Volume Tab, check the box marked "Place Volume Icon in the Task Bar" and click apply
  Hope this will help
Answered By 15 points N/A #81895
It is likely that the devices associated with these headers don't have their drivers installed yet, that's why instead of showing up under Sound, Audio and Game Controller, they would show up elsewhere. Well first make sure your audio hardware is installed.
That is, if you're using a discrete sound card, make sure it is installed and seated properly. If you are using the integrated sound or audio controller, then you may just go to the Device Manager and look for entries under Other Devices. The entries under here are those devices without any drivers installed. Just make sure you install the right sound and audio drivers and you should be able to see the right entries.
