No of visitors who read this post: 1076
Category: Internet
Type: Question
No votes yet
Hi team ,
I got “Demo limit” problem when I try to construct my project by mikroC pro which is purchase by my professor Mortier Bruno for pic. I did all install task of mikroC but it displaying “register to: Mortier Bruno”
Please help and Thanks in advance.
Comment viewing options
# (Solution Accepted)
If you got a Demo Limit error message while using the application, it means that there is a component or a tool in the application that is only available for registered versions only. Obviously, the application that you are using is only a demo version and not a registered version. You can still use the application but with some limitations like the one that you just encountered.
If you want that error message to disappear, tell your professor to register the software because you are having a problem using it. Registering a software means you need to pay for a registration code or a license code that will be sent to your professor since he is the one registered in the software.
Regards
Sharath Reddy
Demo limit mean you have already reach the maximum time to use particular software as demo or it is commonly known as 30 days trial. If that software was registered to your professor Mortier Bruno, and the license is OEM or a single license, you can’t use the license key to other computers. If the software is currently installed in your professor’s computer and you are using it in your computer, the software owner might detect that you are using pirated software because you are using the license that your professor is using.
Try to un-install the software from your professor’s computer (if he will allow you) then install it in your computer.
Your last resort is to purchase another copy of that software.
I had no idea thats how it works. I asked my professor about registering it. He said it was registered. I also told him about the problem. So we decided to purchase a new one for myself. Thanks Techyv team, It was helpful.
