Defragmentation of hard disk loading issues
Asked By 120 points N/A Posted on -
I am facing issue in opening of various applications install on my system. It is taking more time to load.
My system disk is almost full. Is there a way I can speed of the application load process on my Windows XP system?
Best Answer by Ronnie
Answered By 0 points N/A #86043
Please try and use defragmentation of your hard disk. Defragmentation in Windows is a process where files are rewritten in an adjoining sector on the hard drive. This results in speedy retrieval and access to files for subsequent use. Your application will then load faster as compared to earlier. To defragment a disk on Windows XP, try this:
  1. Go to a drive on your hard disk.
  2. Right click on the drive, go to properties and click on Tools tab.
  3. Select the option Defragment now.
Answered By 120 points N/A #86044
Thanks Ronnie for your advice. I tried it on my system and it worked. Have a great day!
