No of visitors who read this post: 1396
Category: Windows 7
Type: Question
No votes yet
Hi experts
I am using a Windows 7 machine (64 bit). When I attempted to install Dameware Mini Remote Control to it, I find the following error:
DameWare Mini Remote Control - Service
Unable to copy
C:\Program Files (x86)\DameWare Development\DameWare Mini Remote Control\DWRCS.EXE
To
\\dong-gw\Admin$\SysWOW64\DWRCS.EXE.
System Error: 5
System Message:
Access is denied
Need to solve this. Thanks a lot.
Comment viewing options
Hey Joseph matthews!
Do not worry about this problem. I had also the same error. I search for this error on the internet. There were many solutions to solve this error. But none of them worked for me. I was stuck badly in this error.
Anyways, I found the solution by myself. It was a simple solution that solved my problem. What you need to is just to follow these steps and you will overcome this problem.
Open My computer and go to the following address
Note: This path will be change in case. You do not install DameViewer to the default folder.
In that folder you will found these files:
  • DWRCST.EXE
  • DWRCSh64.DLX
  • DWRCSET.DLL
  • DWRCK.DLL
  • DWRCS.EXE
You have to copy these files and paste them in the following path:
C:\Windows\SysWOW64
Now double click on DWRCS.EXE, this time it will run successfully.
Thanks
