C:WindowsSystem32zigulavo.dll is not a valid Windows image
Hello Guys,
My machine running with Windows XP service pack 3 has encountered a problem. An awful error message is appearing every time during running an application. It says, “C:WindowsSystem32zigulavo.dll is not a valid Windows image”. What does it mean?
Please help me to get a remedy of this issue.
Answered By 0 points N/A #156690
I suspect that your computer is infected by a Malware. That is the reason you are getting this error message. Please check whether the application that you are trying to open is a genuine application. I suggest you to install any Malware removal tool on your computer and perform a scan. If you have any Antivirus program installed on your computer and it is updated, first run a full system scan on it before installing the Malware removal tool.
Just in case the above issues do not fix your issue, I suggest you to restore your computer to a previous stage. This should definitely fix the issue on your computer.
Thanks and regards,
Skarbos Jay.
