Great day to all!
While I was browsing the internet using Mozilla Firefox, it stopped and gave me an error message: Could not initialize the browser’s security component. I pasted below the whole content of the error message.
Alert
Could not initialize the browser’s security component. The most likely cause is problems with files in your browser’s profile directory. Please check that this directory has no read/write restrictions and your hard disks is not full or close to full. It is recommended that you exit the browser and fix the problem. If you continue to use this browser session, you might see incorrect browser behavior when accessing security features.
As I read the error message, lots of headaches were given to me. It is because I am not a technical person to understand the error. I also found nothing when I searched the internet for similar error. That is why I tried to post this issue here on techyv, hoping to get some ideas on my problem. Thanks for reading my post.
Here explains the causes of this error message in FireFox.
‘ERROR MESSAGE’
‘Could not initialize the browser's security component. The most likely cause is problems with files in your browser's profile directory. Please check that this directory has no read\write restrictions and your hard disk is not full or close to full. It is recommended that you exit the browser and fix the problem. If you continue to use this browser session, you might see incorrect browser behavior when accessing security features.’
The causes are the following.
If free space available is less than 1MB, extra space is needed.
Martyables,
Your problem here is very easy to be solved, as long as the system has specified the errors incurred. The main thing you need to do in this case is to check the memory of your hard disk and the registry or the 'directory' as it has been noted. As you can see, in this case, the most likely error is the space in your hard drive. You will need to reduce the memory of your local disk by using these steps;
This should solve the error.
