The cooling fan is making annoying sound
I have a desktop pc where I work on over 15 hours a day. So I really have to pass a lot of time around it. Recently it is making some annoying sound which I think is caused by the cooling fan inside near the power supply. I have tried to figure out what happened but could not do so. Please give me some suggestion on how to make this annoying sound stop.
Karlos Hilton
Best Answer by Alex Radacinas
Answered By 5 points N/A #115820
Hello Karlos!
I think the problem involves in your power supply. The fan inside the box is probably broken that is why there is some annoying sound. It is crucial , so don't use the power supply and replaced it with a new one. Don't bother opening the power supply because it is not advisable to do so. It is for the safety of your unit and yourself too. You can get some power supply in computer merchandises and they are cheap. I hope I've helped you with this problem. By the way bring your unit if you want it to be replaced so that you can get the proper model for your CPU.
Take care.
Answered By 0 points N/A #115821
Genebraldo Regio. Hi,
This is just a simple problem. Dust and other small particles will block your cooling fans and heat sink in your PSU. You can fully clean your PC by using vacuum cleaner. If it is a hardware conflict noise, shut down your PC quickly and then Check PSU again.
Be careful, storage charges may be there. Don’t blow your PSU. It directly affects your motherboard and other devices.
If you really can’t, better get help from a Genius.
Good luck
