Convert PDF document Hebrew to Word
I need to convert PDF document Hebrew to word, usually I use Adobe professional to do the same, but I am unable to get the
Hebrew even after installing the specified font,
Please suggest me any other extraction method, that will help me to extract the PDF with Hebrew characters to word.
Answered By 0 points N/A #153126
Adobe would help indeed. Use Adobe Acrobat to convert the PDF to word.
However,you may find that Hebrew may be "backwards" after conversion (i.e., the text may be displayed left to right rather than right to left).
To fix this issue, try converting this doc with “backward” text back to a PDF file.
Next ,open the newly converted PDF to word to get required word doc with correct text display in Hebrew.
