Convert English to Hindi in Java Mobiles
Hello Techyv Guys,
I am in need of a Mobile Phone application that will convert English to Hindi in Java Mobiles. Have anyone of you heard about such Java application, If so please do the needful for helping me by suggesting me the application name.
Thanks in Advance,
Alex A Gonzales
Best Answer by Aron Hank
Answered By 0 points N/A #172347
You can download a software for English to Hindi translator from here. The translator provides you the Hindi translation for English text typed without any need of Hindi support on your phone.
 You can also look here for English to Hindi dictionary. It works on mobiles like Nokia, Samsung, Motorola, LG, or RIM phone.
Answered By 0 points N/A #172349
I would have to recommend the Google Translate app to you. It is available for most devices and is by far the most comprehensive translation program out there. Simply input the desired text, choose the languages and away you go. There are other translation apps, but definitely give that a try first.
Answered By 0 points N/A #172350
I have an answer to your question as follows:
On Java cell phone just go to language option in text messaging.
Select Hindi as a language instead of English.
This will make your phone in Hindi language not in English.
This will resolve your problem of language conversion into english by following above details.
