No of visitors who read this post: 207
Category: Misc Software
Type: Question
Author: Clara_Harris
No votes yet
I have experience in web developing like PHP & My SQL. But, I want to change this technical field. I am interested to try with SAP domain. But, I don’t have any idea about SAP. I want to know, what I have to do. Is one year experience in PHP/My SQL is enough to take SAP course? I know it is demand. Please guide me.
Comment viewing options
# (Solution Accepted)
Hay Clara,
At first you have to think about your work review. How you have demanded on this work or your career? If you naturally want to learn it for only knowledge then learn it, if it is for your career you would think over your ability or log in position after SAP course. This is true it's very demand. You add your experience over PHP, My SQL. This is best foundation for learn SAP course without thinking you can do it. Any kind of programming course will very essential for competitive world. No need to guide others just confidently do it my friend.
Have a good time.
You need to assess your prowess in the programming field before venturing into SAP. It is only you who is in the most favorable position to evaluate whether you have the necessary talent to jump into it. With your prior experience in PHP and MySQL, you are in a good position to take SAP, and if you are an expert in the above fields i am sure you will do well in SAP as well.
