Connect two computers with internet and VPN connections
I am under a network with two routers with distinct IP address connected together. The first router is used for accessing internet while the other one is used for making VPN connection in other place. What do I need to do to allow a Windows 2000 or Windows XP PC to have access on both locations? That is for the internet and VPN.  And also, I need the two gateways to be in a single port. Can someone please help?
Answered By 0 points N/A #123106
First of all you have to connect the first router with your internet provider,make sure the internet is working..After this you have to connect the other router with the first router through the ethernet cable.Make sure that there is no IP conflict and switch ON the other router, do the IP settings and it should work.If you want to connect both router wirelessly you have to bridge them and you have to follow the bridging steps,do the IP settings of the both routers properly.After doing all the steps restart the routers and it will work.
