No of visitors who read this post: 726
Type: Question
Author: Emimayer
No votes yet
When I am using Windows Update, the error code 80040154 appears; also, I get the following message "Class Not Registered".
What should I do to solve this? Need your help.
Thanks in advance.
Comment viewing options
This is a windows problem that can be fixed in the following way:
1. Go to http://support.microsoft.com/kb/971058
2. After login to the web site you will see a Microsoft Fix it dialog box.
3. On the bottom right corner of the box , you will see Run now button, click on it and download the Microsoft Fix it Application.
4. After downloading run the program, it will as you to restart the computer.
5. Restart and the application will fix the program.
# (Solution Accepted)
Hello!
If you haven't already submitted a support case and is still getting this error, here are some things you can try. You need to run these tools and see if any of them report errors that can't be fixed.
To fix this problem, you have to try the following:
  1. You have to check Disk Error first.
  2. You have to check the system file checker.
  3. You have to check the system update readiness tool
If the above solutions come up as clean, you have to scan your system with another anti-virus or anti-malware software. It is highly recommended to use Microsoft security essential from Microsoft Corporation.
