CISCO ASA 5505 Router Could Not Connect
I am having problems connecting with the internet. I bought a CISCO ASA 5505 router and it was configured by CISCO Technical Support Personnel. The router is working well but the last couple of days; it just keeps on resetting itself then restart that causes my network connection to stop working correctly. It will stop then reconnects again after few minutes.  Please send me help me on this. Thanks.
Answered By 15 points N/A #126546
How many devices use this router? Is the router located in a very tight spot without much air movement or is it placed in an open space where hot air can easily flow? It is likely that the router may be heating up too much that's why it is restarting or resetting itself. Try placing the router in a way where the vents are not obstructed and air can flow unhindered. Also try resetting the router once, the reconfigure it and observe. If it still does it, call CISCO and have it replaced. You may have a faulty router already.
