No of visitors who read this post: 403
Type: Question
No votes yet
Hi experts,
When I tried to open my Cisco AnyConnect VPN client, I got the following error. The weird thing is that I opened it yesterday and it worked fine. Does anyone know why this happened? Is it because of a virus?
Thanks!
Error:
The VPN client driver has encountered an error
Comment viewing options
It's actually a CISCO bug. To deal with it you can:
1)  Install the newer version which has the bug fixed and avoid the trouble of dealing with this bug.
2)  Disable routing and remote access service which windows enable then try starting AnyConnect. Remember to open the cmd as Administrator to do this fix.
3)  Unintall Cisco AnyConnect VPN client and completely delete all its folders on your hard disk then install it again. Doing that worked with some users.
