Characteristics of Ceno PDF 3.6.161.0 plugins and its importance
Hello, I need some answers about Ceno PDF 3.6.161.0 plugins is that
I want to add a check box, radio button, Can I add this feature to use Ceno PDF 3.6.161.0? Can I resize and relocate to use new plugins? Is it kept disable auto-saving function for using this? Can I import data from any database by using Ceno PDF 3.6.161.0? Can I export PDF doc to Microsoft PowerPoint? Thank You
Answered By 0 points N/A #189130
CenoPDF is a Microsoft Word plug-in that allows you to add check boxes, radio buttons or combo boxes into PDF documents.  It requires that your Microsoft Word is updated to the latest version of Office, which means your Microsoft Word has to be updated with the latest Service Pack.
CenoPDF is a WYSIWYG (What You See Is What You Get) based program, which means that if you aren’t happy with the size or layout of menus in the program, you can customize it by moving or resizing it to your satisfaction.
The features of the program include creation of templates that can be filled with data that has been created in any database or an Excel Spreadsheet, you can export PDF files directly from Microsoft Excel and PowerPoint, and you can Edit, Convert, Save and Export PDF files from within Microsoft Word or Publisher.  The only drawback to this program is that it disables the auto-saving function in Microsoft Word.
