I use Nokia 5130 mobile phone. But recently I flash my mobile phone for corrupted file. After setup a new software I cant use my Built-in browser. When I browsing through the browser the connection of EDGE got down and no webpage is open. What should I do now?
Nokia 5130 has a built-in Opera Mini Browser.
The very first thing you should do is try to Restore Factory Settings of your handset. If doesn't work, you may download another copy of opera mini.Refer to this link: Download Link
After you download it, try to install it.
You should also save the received configuration settings from your service provider. It is required for browsing.
I hope that this will help you.
Hi there user:
The essence of using Nokia Brand phone is you get software available by the website. Your brand has its own software; you will only need to use the same software built in your phone. Download the Nokia Suite for PC. http://www.nokia.com/global/support/software-update/ Type your Nokia Model and Version. You can find it in your phone, just type *#0000# and you’ll see your version and model on your screen. Connect the USB cord from PC to your Nokia phone. From the Nokia PC Suite, click the reinstall software.
You can now use your built-in browser.
Problem solved!
Best regards,
Edmund Joseph
