Cannot visit certain sites with internet explorer
My internet explorer is not getting access to few sites which can be browsed with Mozilla Firefox. What is the reason behind this. I only use two browsers and for my convenience in work I need multiple browsers. If there is a way to make it happen for internet explorer to work, please let me know.
Spencer Reynoso
Best Answer by Morcelo Toldelo
Answered By 0 points N/A #117560
On Internet Explorer
– Tools Menu > Internet Option > Security Tab > Click on Reset all zones to default level.
– Tools Menu > Internet Options > Advanced Tab > Click on Reset at the bottom.
Answered By 10 points N/A #117561
Internet explorer may not get accessed to few sites which can be browsed with Mozilla Firefox. There may have some little reasons behind that. Previous person has advised to set up security of your internet explorer browser. It may solve your problem.
But if it was not solve then try to check which version of internet explorer you are using. If you are using a previous version of internet explorer browser then please update your internet explorer. Updated internet explorer is more advanced and previous versions are not supported by different sites of the day.
For an updated internet explorer please visit:https://support.microsoft.com/en-us/help/17621/internet-explorer-downloads .
Answered By 10 points N/A #117562
Morcelo Toldelo, thanks. Your deduction was correct. I installed the latest version of internet explorer. Now, I can easily access websites using IE. Thank you very much. I'm glad I consulted in techyv.
