No of visitors who read this post: 1659
Type: Question
No votes yet
I cannot get the searcu toolbar inactive from default webpage in my mozilla firefox browser. I have tried to reset the default settings but it did not work. So I am in some inconvenience and like to solve the problem.
If someone can help me please suggest me how to get it out of default start page.
Christian Briggs
Comment viewing options
Hello Christian,
I don’t have the searcu toolbar so I’m going to use another one to make an example.
If you want to disable the toolbar:
  1. Go to the Add-on manager tab (press Alt then go to Tools>Add-on or press Ctrl+Shift+A)
  2. There click Extensions and click on Disable on the right of tool-bar’s row.
  3. Then restart Firefox and the tool-bar will be gone.
If you want to reset your home page:
  1. Go to the Options window(press Alter then go to Tools>Options)
  2. There on the General tab you will find Restore to Default, click on it and restart Firefox.
Hope that fixes your problem.
