Cannot open files with kmp media player
I have been using kmp for a while now. I have suddenly faced which I have not encountered before.
The kmp browser is showing a code error, and I do not know why is this happening.
Should someone know how to solve this problem please let me know. I will be glad if someone quickly solve this problem for me.
Kenneth Feugo
No combination of filter scould be found to render the stream.
Error Num: 80040218
Binary Info:
Data:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Best Answer by Mehedi Hasan
Answered By 0 points N/A #116927
There can be two problems as far as I know.
 One problem, your file is broken. If your file is broken then nothing can do with it. If broken therefore you should download it again and try. I hope it will work if your file is broken. If your file is partially downloaded then you will face this problem or if your file stopped at the middle of download then it can happen.
Another problem is codec related. If you do not have codec then you have to download it. Download k-light mega code. Make sure that your video or audio file is not broken.
Answered By 0 points N/A #195189
You are receiving this error due to the following reason:
1. You are trying to play a media file that has a file format not supported with KMP Media Player.
2. You need to update to the recent version of KMP Media Player. You can get the update.
3. There is a registry key missing or corrupted.
4. A missing codec to play your media file.
Check on each and see where the problem really comes from. Search for the correct codec. KMP supports AC3, DTS, MPEG1 and 2, AAC, OGG, WMA 7 and more. Check if the file you are trying to play is supported. Additionally, you may need to download the most recent version of MS DirectX.  When you check your registry key, be sure to back up your system first so in any case that you mistakenly save a wrong key, you can still restore your computer system.
