I am getting this error message during the installation of Oracle Database 11g XE. What’s wrong with ? The installer is unable to instantiate the file. You can see the error image attached below. Please share some ideas to resolve this error. I am waiting for an expert’s advice. Thanks in advance.
Error
C:UsersMCLAUG~1AppDataLocalTemp{078E83D7-3FCC-4A7
2-9038-995C7CE44681}KEY_XE.reg. The file does not appear to exist.
Cannot install Oracle Database 11g XE
Hi Lorraine,
The installation would have gone through, albeit not completely. Try the below steps to see if it helps:
1.Browse to D:ORACLE_HOMEapporacleproduct11.2.0server path(ORACLE installation directory)
2. Right click on Get_Started.url ->select properties->Web document Tab->modify with this url http://127.0.0.1:8081/apex/f?p=4950:1:332920099833260
3.Port number must be as per your HTTP port number or try 8080
4. Verify that Tomcat server running
5. Click on Get started link from All programs->Oracle Database 11g Express Edition
