No of visitors who read this post:
247
Category:
Page Layout Software
Type:
Question
Author:
Ashley adams
I upgraded my Windows XP to Windows 7 then installed Photoshop 7.0 again on my new OS. But I cannot access the options tool bar. The shapes and line icons are there but do not open. And also, instead of the default arrow cursor, there is a strange grouping of three miniature icons. Is it possible to run Photoshop 7.0 on my new OS without problems? I’m in plumbing field and I am using Photoshop on laying out plumbing pipes and fixtures for my floor plans. Please help me fix it. Thank you.
I'm sorry but you are running Adobe Photoshop 7.0 on the wrong version of Windows. To give you the detailed information on the application’s specifications, read the information below:
Obviously, you are not running the application in the right operating system. That’s why you are seeing strange icons on the panel and the toolbar is not accessible. Since you are using Windows 7, visit Adobe’s website at http://www.adobe.com/products/photoshopfamily.html?promoid=IUGXD so you can find the right version for your Windows.
Regards
Sharath Reddy
