Can we install office 2007 and Office 2013 on one system?
I want to have both office versions on my system. Is this possible and if yes what are the steps and if no what are the tweaks to achieve such a setup
Answered By points N/A #155074
It is possible to have such configuration.
1. First of all, obtain the copies of both Office 2007 and Office 2013.
2. Install any of the office suites. I recommend you to install Office 2007 first.
3. Then, run Office 2013 setup.
4. When prompted, you will be asked to choose the following options:
  • Keep existing office
  • Remove the old one and install the new one
5. Select keep existing office
6. Then, complete the process.
Now, you will be able to use both Office suits together on the same system. But it is better not to use this because it might make any conflicting with each other and produce error.
