Can someone give me any idea on smart defrag 2 skins download?
Hi guys,
Can someone give me any idea on smart defrag 2 skins download? Does it buggy or unresponsive once it finished downloaded and installed in a netbook? Where does smart defrag 2 skins download and how does it affect in a system?
Answered By 5 points N/A #195234
Hi Johnnierbailey, thank you for sending this in.
I would like to know if your netbook has windows 7 installed as its OS? If so, then downloading and using skins on smart defrag 2 should have no problem and will work as it should. The issue of being buggy and unresponsive smart defrag 2 skins only affects older machines, i.e, machines with graphics card drivers that hasn't been updated by the manufacturer, those that still use windows XP as OS and 32bit OS machines.
Hope this helps!
