Can I use CSS in WordPress?
Can I use CSS in wordpress?
Im new to wordpress. Just switch from blogger to wordpress because they say wordpress is more userfriendly than blogger. I know a little about Css and html. Now my question is can I use css in customizing my wordpress page?
Answered By 15 points N/A #80551
Hi Jennifer,
For sure you can use CSS in word press. You can use and Edit Cascading Style Sheets by accessing it from the appearance menu of your dashboard in your word press blog.  You can edit your CSS, preview changes, change styles without affecting the public view of your blog. You can edit it and save the style sheet any time you like, upload pictures and other images and modify backgrounds, and generally change your blog to suit your taste and feel depending on its functionality.
Modify themes, customize forums and so forth; all using CSS.
Hope this helps.
-alphae-
