Can I merge corel files into one? Please help!
Hello techyv.com!
I have here multiple files of corel draw editing format files. This were my files for like many years ago, for I'am now using other programs for photoshop. Anyways, I guess those files that I have were still good for editing, yet I want to merge them. I can't seem to find a way. Please teach me if there is a way to merge corel files into one?
Best Answer by Lloyd S Lebron
Answered By 60 points N/A #138608
Just use the import function. Simply open the first Corel file and then import the second file. Save it on a new page and just repeat the same steps until you finished importing all your Corel files. Or you can also publish your Corel files to PDF. Ensure that all the files are open but just limit the files to 10 pages. Search for the Publish to PDF dialog box and select the multiple documents and your files will be published on the PDF file.
Answered By 25 points N/A #138607
Hello Alice Macek,
I have not enough knowledge about Corel Draw. When searching I have found some solution.
1. Just open one of the files, then import another and place it in a new page and repeat as you needed.
Or
2. Open all of your corel files and then Publish to PDF, click Settings, then click Documents, all of your corel documents should be checked and make other changes you required and then save. That will make all corel files into a single PDF file.
