Is it true that one anti Spyware isn't enough to protect your computer from internet spyware?
I have downloaded (I will not name drop one anti spyware) an anti spyware but I still have doubts if is enough for my computer's protection.
Can I install many anti spyware in my computer?
And what would be the best anti spyware for the job?
Hello Jane,
I can understand your curiosity about Spyware and Malware entering into your computer. When we look at the internet there is lot of chances for getting viruses into your computer. But you don't want to install more than one anti spyware in to your system. Which will cause you further troubles like, Hang, freezing and slowing down your tasks, Which seems very complicated for me. If you install more than one anti virus it will only make you trouble. So don't do that.
But I can suggest you one great antivirus which will prevent most spyware and malware's. It is AVG 2012. Every user in world wide except this particular antivirus. It is simple to use and totally free. Its updates are available weekly, which will protect your computer from new released spyware's. So choose wisely, don't pick more than one.
Hope you get the answer. Have a nice day
The anti-spyware do not conflict like the antivirus’, is recommended that you use at least two installed on your Personal Computer, such as work requests (MUST RUN THE HAND) one at a time, for that reason does not bother at all between them. The anti-spyware has employ different techniques specifically search algorithms for spyware, which is why it is the other one does not detect it, so it is not advisable to run a single anti-spyware on your PC. Here I show you the anti-spyware that I use and are the most endorsed globally, "FREE"
Spybot Search 1.6.2.46
Spyware-Blaster 4.2
SuperAntiSpyware 4.26
Hi Jane,
Getting an Anti-Spyware is one way of getting your PC protected. You must have a good or I must say reliable anti Spyware like Norton or a AVG just to name a few. (Well they wont be a well known manufacturer for computer's protection if they haven't prove it yet). However giving your pc more than 1 Anti Virus is not recommended. Here's the ff disadvantages:
* Eat up a memory for your PC (can make you computer run slow)
* Mess up registry (your computer can not be maximized its own function)
*Can affect your computer's browser (slower web access)
I suggest for you to learn how to prevent getting malware instead. It like PREVENTION IS BETTER THAN CURE.
Here are some of my tips :
*If your fun of installing free apps or software, make sure to read the agreement (It might be asking you to destroy your pc and you just agreed with it)
*Update driver for both pc and your anti spyware
*Be careful where your browsing
*Aside from anti spyware, be sure that anti firewall is set up aswell
*maximize the use of your anti-spyware
And believe me this work very well.
I had problem with PC spyware for a very long time. Then a very close friend of mine recommended these products to me, ever since then my PC has taken a different turn. Since this system worked for me and my friends, I believe it can also work for anyone; I have free info about this on my site; Link
