Can I get activation code autodesk photo from Autocad website?
I just upgraded to Windows 8 and I'm trying to reinstall Autodesk AutoCAD 2012 but I couldn't find my activation code.  How can I contact  Autodesk and can I get my activation code Autodesk photo 2012 on Autodesk website?
Best Answer by Sinky Lynn
Answered By 0 points N/A #167876
To activate your Autodesk product manually you have to send a request code to Autodesk, who in turn will provide you with an activation code that you will use to activate your Autodesk product.
To request for an activation code:
  1. First Launch the product. On  the activation wizard that appears click ACTIVATE.
  2. The next screen shows your serial number, product key and request code at the top, select CONNECT NOW AND ACTIVATE and click next button at the bottom of that window
  3. If you are using a trial version you will be asked to enter your serial number, product key once you have done it select REQUEST AN ACTIVATION METHOD USING AN OFFLINE METHOD and click next
  4. On the product registration form choose whether product is to be registered to individual or company and the select your country then click next
  5. Fill the customer information form and click next
  6. Select form submit method and follow instructions (email is simplest and cheapest)
  7. On receipt of the activation code re-launch your Autodesk product and select activate
  8. On the activation form select I HAVE AN ACTIVATION CODE, enter the received code and click next for activation to occur
Answered By 0 points N/A #167875
Hello, Kurtt Stewart!
When you activate your product for the first time, you need to fill up a form in the Autodesk registration page. Autodesk will validate your product key and serial number for activation.
They will send back your registration information. If you didn't find any, you may need to seek the assistance of Autodesk by filling a form of License Registration and activation form from their website.
To help you with your problem, here is the direct link.
Hope you can contact them and your problem will be solved.
If you have another issue, check back here again.
Have a good day.
