meigs goll
Posted on - 02/04/2013
Hi friends,
I required an interactive map in flash for longitude and latitude. I searched and found Interactive Flash Map latitude, and many more results. I also wish that I can upload my own maps and import data from other files. Such type of map available in Java Script but I need it in flash format.
Can I found interactive flash map with latitude and longitute information?
You can create Interactive Flash Maps use iMapBuilder which is an Interactive Mapping Software. Maps are interactive with pinpoint, heat map, line drawing, and zooming features and you can also customize interactive flash maps.
With this software you can create maps, using flash map templates and you can import your own map images as well. You can convert JPG, PNG, GIF and SHP image files into an interactive map.
OR
You may use iMapBuilder Online, which is a Cloud-based Interactive Mapping Application. It doesn't require to be downloaded or any installation and runs directly on your browser.
Laz Zebbena
