Can I export iPhone mms through SFTP connection?
I want to export iphone messages especially MMS.Can I do that through SFTP connection? Should I have any program installed to export iphone mms?
Best Answer by Joyce Meghan
Answered By 0 points N/A #146275
You can easily transfer your iphone messages to your computer. For that you will have to download a software called as TouchCopy . Here is the link if you want to download the software https://www.wideanglesoftware.com/touchcopy/index.php
The Software is not free and there's a price of 20$. However there is a free trial available and you can try it. If you feel it does the work required then buy it for future use.
Thanks!
Answered By 0 points N/A #146276
Hello Robert,
Tipard Pro is a fully featured iPhone transfer. It can be used to transfer your MMS, SMS. But it is not an opensource software. You can use this to transfer data within two Apple devices. It supports all Apple devices.
iPhone Backup Extractor is another software you can use to export your MMS.
If you are using a Mac then better check on the PhoneView also.
