Can anyone tell me the shortcut keys for VLC.?
Dear Experts,
I am a user of Winamp version 5.5 and VLC media player 2.0.1. At times I feel quite uncomfortable using a mouse to play, pause, rewind, change of volume etc.
Can anyone tell me the keys for shortcut Winamp VLC?
Best Answer by Rubi Sharlene
Answered By 0 points N/A #151474
There are lots of shortcut keys that can be used in Winamp and VLC media player.
The Basic commands for VLC media player are as below:
Volume: Ctrl + Up arrow key to increase the volume and Ctrl + down arrow key to reduce the volume
Play and Pause: Use Space-bar to Pause and Play
Rewind and Forward:
         Use Alt+ Right arrow key to slow forward and Ctrl+ Right arrow key to Fast Forward
         Use Alt+ Left arrow key to slow rewind and Ctrl + Left arrow key to Fast Rewind
For more and All types of Shortcut keys Click the below link:
https://shortcutworld.com/VLC-Media-Player/win/VLC-Media-Player_Shortcuts
Answered By 0 points N/A #151475
Dear Athan,
I know it's making your life easy when you know the shortcuts.
I will provide you all the necessary shortcuts for VLC and WinAmp.
Shortcuts for the VLC media player
[Spacebar] – Play / Pause
[S] – Stop
[M] – Mute / UnMute
[ + ] – Fastforward
[ – ] – Play Slower
[Ctrl] + [UP Arrow] – Volume UP
[Ctrl] + [Down Arrow] – Volume Down
[N] – Next Item
[P] – Previous Item
[Shift] + [Right Arrow] – Move 3 seconds forward
[Shift] + [Left Arrow] – Move 3 seconds backward
[Alt] + [Right Arrow] – Move 10 seconds forward
[Alt] + [Left Arrow] – Move 10 seconds backward
[Ctrl] + [Right Arrow] – Move 1 minute forward
[Ctrl] + [Left Arrow] – Move 1 minute backward
Shortcut keys for WinAmp 5.5
[X] – Play
[V] – Stop
[C] – Pause / Unpause
[B] – Play next track
[Z] – Play previous track
[Right Arrow] – Fast forward 5 seconds
[Left Arrow] – Rewind 5 seconds
[Up Arrow] – Increase volume
[Down Arrow] – Decrease volume
[R] – Toggle repeat
[S] – Toggle shuffle
[Ctrl] + [N] – New playlist
[Ctrl] + [O] – Open playlist
[Ctrl] + [S] – Save Playlist
[Enter] – Play selected track
[L] – Add a file
Thank you.
Rubi Sharlene.
