I recently purchased Acer S3-391-6470 with pre-installed Windows 7. I formatted C drive and installed XP myself, since then I’m having problem finding drivers for Windows XP. Can anybody help me to find drivers for Windows XP?
If you installed XP yourself, you should check if the installation went well as first. Maybe you should try doing the whole thing again and doing it more carefully.
Then, I suggest the official page where you can find drivers for almost everything, and plus it`s free. http://support.acer.com/us/en/default.aspx
There you go, this is the link.
I hope this turns out in your favor.
Hello Dear,
Thanks that you have shared your problem with us.
Dear if you want to get all drivers, then you have to note your all hardware's models and manufacturer.
It is a very painful task. I am going to tell you a very easy method.
Just go to this website.
http://www.driveridentifier.com
This web site provides software called "Driver Identifier" just download it and install it on your PC.
It will scan your computer for drivers and open the driver download page.
Simply download that driver, install them, restart your PC and enjoy.
Thanks
To download the drivers you need, you should go to the manufacturer's website. Acer has their product support webpage wherein you can be able to get all the drivers you need. Just simply go to the link below:
http://us.acer.com/ac/en/US/content/drivers
Select your Operating System and then download the appropriate drivers you need.
