For last few days I am getting slow performance in my desktop and OS I have in my pc is XP. I have short knowledge about pc troubleshooting and called one of my friends for help and he is a technical person. He suggests me to stop some software loading at windows startup and uninstall the software which I am not using regularly and he also told me the total process to do it. I have done it as per my friend’s instruction. But I can see a program in the taskbar called windows messenger is still running. I can’t remove or stop it. My friend is not around currently that’s why I need your help.
Hi Truman,
To be sure, you can also disable it by doing the following:
Hope this helps, tell me if those 2 ways still doesn’t work.
I have read the issue that you have on the computer and slow connection could be cause by a virus infection on the computer. I will suggest you have full scan of the computer first with your virus protection and then check if there are viruses infecting the computer. Remove the viruses if there are any. If you’re not using a virus protection and you don’t have any software to check, you can install malware bytes on the computer and use it to scan the computer.
To install it, here are some steps:
If there are no viruses on the computer, try turning off the devices, the modem, router and the computer, for 30 seconds and the first device you’ll gonna turn on is the modem and then followed by the router (if you are using one) and then last is the computer. Check the speed of the connection by going to this speed test site and checking your speed.
This next step is uninstalling the software on the computer, if you don’t know the important software that the computer use, do not uninstall any software, just look for the yahoo messenger that you’re having issues with.
If you just want to disable the application here are the steps
Here are the steps that you need to do and hopefully I have somehow helped you with the issue.
