Buying exclusive web templates or hiring some designer
I want to build a site and I want the process to be cost-saving, so buying exclusive web templates or hiring some designer for custom design, which of the two is cheaper?
Best Answer by Alcaraz Jody
Answered By 5 points N/A #159843
Dear Brady,
It actually depends. If you know some web development then buying a web template would be the better option for you. But if you have no idea about web programming and you might have to do customization over and over on your website then hiring a web programmer will be better option. Best of Luck.
Answered By 5 points N/A #159844
Dear Brady collins,
To have a website with lowest cost and good quality I recommended buying exclusive templates it is a fast guaranteed way, or you should think about Google apps that enables you to build your website without learning html. But for special advice you must learn more about websites as you will have to do maintenance usually, so to be cost effective you must study a little
Answered By 20 points N/A #159845
Thanks guys. Alcaraz Jody, your opinion is awesome. I really like your recommendation to me about exclusive templates. Because I don’t know much about programming, I think I will need to buy a website template. Exclusive templates are the most economical way to start up or refresh my website. I can install them into any of the approved web hosts or I can opt to self-install and this way it will be cheaper for me too.
