No of visitors who read this post:
176
Category:
Page Layout Software
Type:
Question
Author:
Karengsam
Books application is showing me an error. What is the reason?
Error:
Configuration error:There is a problem with the configuration of your iPhone. Please restore with ITunes or redownload iBooks.
IPhone developer says, "They Will release a software that can solve all the error in iBooks and eBooks". You may solve your problem with my explanation. If you have not jailbroken in your IPhone so please installed it in your IPhone then it will be not happened. Make sure you've it.
On the other hand you may solve this problem to visit "www.iphonefaq.org". Uninstalled the books application and redownload it and also reinstalled it. That can also solve your problem. When you redownload the application make sure that the application is not damage or corrupted. Then it will be worked properly.
Thanks,
Edward Santoso
