Best tutorial for WP template – any suggestion?
Recently I'm trying to learn how to make WP template by myself. But I couldn't make a single one work on WP 3.5 so far. So I decided to take help from several WP expert forums. I found many WP template making tutorial but all are lacks in detailed information. I need step by step and explanation of each code used in the template – kind of tutorial. Can anyone help me with that.
Waiting for you response.
Jessie
Answered By 0 points N/A #144049
We'll start with the Header (header.php) and INDEX (index.php). So open your header.php template and enter the following data there :
As a result, we will use the template tags. The template tags are small pieces of code in PHP files cont connect them. This line of code is as follows:
Save your template index.php.
Open the CSS file created earlier and enter the following content:
You can edit this information by replacing the ones you want. This is particularly the ones that will allow the display of your theme in WordPress administration.
