No of visitors who read this post: 194
Type: Question
Author: Eliza dunley
No votes yet
It’s been two months that my system is slowing down and my friend suggested me to check hard drive health and I was wondering if someone may suggest me best third party tool available for this purpose? Any kind of help would be appreciated.
Comment viewing options
# (Solution Accepted)
Hi ,
There are various types of software which can be used as Hard Disk diagnostic tools. Just download any software from Internet. You can also use Hard Disk utility software to keep your PC healthy.
Here is an URL link that provides tutorial about some Hard Disk health checking software.
http://www.makeuseof.com/tag/all-the-tools-you-need-to-predict-the-death-of-your-hard-drive/
I hope it will be helpful.
Dear user,
the best third party application you can have to check your hard disk and fix it is the application provided by your HDD brand. for and example. if it is a Seagate hard disk you should get that software provided by Seagate
you can find them in here,
http://www.seagate.com/support/downloads/
Also if you are looking to improve and increase your hard disk health and speed.
You should clean install everything in your PC. And yes I am talking about full format.
Thank you
