Best online eBook Korean language translator on web.
Asked By 100 points N/A Posted on -
My friend sent me an eBook via E-mail which is half English and half Korean.
I was wondering if someone knows if it is possible to translate Korean to English online.
If someone knows any eBook Korean language translator online, then it would be appreciated.
Best Answer by fresherwink
Answered By 10 points N/A #133772
Hey Hollis Riley!
I would suggest two online tools to help you translate:
You can download or use Babylon 9 online. It's a great translation software.
You can also use Google Translate to translate from Korean to English as you require:
Answered By 0 points N/A #133773
Hello Hollis Riley,
Yap. it's there quick way to convert your Korean Ebook to english.
First you need to upload the document to an online viewer like zoho viewer
Second paste the link Ebook you've just uploaded to Google Translate with setting from Korean to english.
Third you can read it.
Hope this solution helps you.
cianida,
Answered By 0 points N/A #133774
Hi Hollis Riley bro,
So you need an online translator,don't you?i would suggest you to use these following sites.
I am sure will be benefited by using these links.
The best way is to use Google translator which is immensely popular throughout the world.
Links are given below:
Dictionary Translator
English to Korean Translation
Korean to English Translation
Answered By 0 points N/A #133775
There are many websites that help you to translate your book but in my personal experience, I can assure that nothing is enough effective to translate the language.
Most of the language translator sites or software use word to word conversion. But if it is more important to you to get the original translation or you need the original speech then I suggest you to translate it by a native speaker.
So you need to find a native to translate your book. You can easily hire them from any freelancing market.
I prefer www(.)odesk(.) com . And you can easily get your book translate with 100% accuracy.
Best wishes for you.
Answered By 0 points N/A #133776
There are many language translators online.  Available also are language translator software.
However it is advisable that you have a virus protector on your pc before downloading any software.
Google provides online translator; It provides you with the options of translating from English to other languages and from other languages to English
Good luck.
