Best Anti Virus and information
You know that Kaspersky is so popular antivirus and we also know that Kaspersky internet security slow our computer and Norton security also popular antivirus but this update file is so big.
But My Question is what kind of antivirus gives better performance don't slow our computer and his update file is not big?
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #161163
Hi Rawpaak1,
Well, if you’re using Microsoft windows the best antivirus is Microsoft Security Essential. This will never slow your computer performance. Or else you may try Avira antivirus, this will not slow your computer and will give you the best performance just like the leading antivirus in the market.
Answered By 0 points N/A #161164
The most recommended antivirus for Windows systems is the house made Security Essentials, of course. It is very easy to use and works in the background so that you almost never have to interact with it.
The product is free of charge.
Answered By 0 points N/A #161165
There are lots of antivirus systems which can help you to stay safe from viruses. Vital information resources under seize of VIRUS can cause several damages to your computer.
That's why people use different types of anti-virus system which can help them to stay away from the virus.
There are many well known anti-virus system to use. McAfee, Norton, Kaspersky, AVG, Avast, is the most popular and common system people can use. Although Kaspersky can slow down your computer but it's a powerful anti-virus system.
In my opinion, I recommended a very fast and trusted anti-virus system which can solve many problems along with detecting viruses from your computer. It's 'ESET Smart Security'. It will not slow down your computer system.
You can simply go to this site-
Download it.
Install it.
Some later versions also released a couple of days ago. Hope you will like it.
Answered By 10 points N/A #161166
For a trusted and free antivirus I would definitely suggest AVG.  It is one of the most popular free Antivirus among computer users in the world. Anyway, visit this Techyv post to get more useful information.
Free and trusted anti-virus or anti-spyware
