AVS Audio Converter Troubleshooting occurred
AVS Audio Converter not to turn to format WMA using the CODEC of voice of WM; it gave the following message;
To convert to WMA format using the WMA Speech CODEC
Error
To convert to WMA format using the WMA Speech CODEC, you need to download and install a special package for Windows Media format. Click ‘ Learn More…….’to download it.
I can't download this. Help Me to resolve this issue soon …
Best Answer by Jiraalbert Namat
Answered By 0 points N/A #150303
AVS Audio Editor represents audio devices that are disabled in the audio devices list above Windows 7. But a user cannot enable them.
If you want to fix the problem, click on the Option Button or the advanced button shown on the Record Tab and switch to open options windows. Click the Windows Recording control button that will open Windows sound recording dialog Window. Then click anywhere where you have opened the Window with the right click button of your mouse and choose the show disabled menu.
All the disabled devices will be shown in a dialog box. Click right click button of your mouse and select the necessary audio devices that you want to work with. Then right click again and select "enable from the menu and close the window by clicking OK Button. Necessary devices will be available on the list.
Thank You.
Answered By points N/A #150304
In order to fix this issue, make sure that your OS contains several components to perform the task.
First, make sure that you have Windows Media Player 11 installed on your system. It is very important for playing WMA files. Download Windows Media Player 11.
Also, make sure that this especial codec is installed on your system. Download according to your OS and architecture:
Now your problem should have solved.
