AvatorBox.exe cannot start due Entry Point Not Found
I just installed on my laptop Avator Box and when I tried to open the program this error appeared. The reinstall is not helping at all and the installer is not corrupt. Any solution for this one ? Can anyone tell me please if I did something wrong ?
Thank you !
The procedure entry point SetLanguage could not be located in the dynamic link library C:Avatorbox-V_6.513AvatorBox.exe.
Answered By 590495 points N/A #179409
I think you have an incompatible application on your computer. Make sure the program you installed is compatible or supports Microsoft Windows 8. Since you are using Windows 8, try downloading the latest version: Avatorbox 2014 or directly download the file from Avatorbox 2014 Installer. It is an 18 MB RAR file so you need WinRAR to unpack the files or use other file extractors like 7-Zip.
Once downloaded, uninstall your current Avatorbox then click Start, All Programs, Accessories, System Tools then select Disk Cleanup. Select drive C then click OK. Check “Temporary files” and Setup Log Files, click OK then click Delete Files. Restart the computer then install the newly downloaded Avatorbox 2014. You need to unpack the files first to get the actual installer.
