AutoCAD Just-in-Time (JIT) Not Supported
Hello! Good day. While working with the AutoCAD, an error came up stating “unhandled exception has occurred in a component in your application”. It stated also that the application does not support just-in-time (JIT).
Kindly help me in fixing this issue. Thank You!
Auto CAD
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Key not valid for use in specified state.”
Answered By 590495 points N/A #150613
Depending on what kind of AutoCAD application you are using, check the system requirements of the application and then verify it with the system specifications of your own computer. Before running this application, your machine should pass all the components that are required by the program. The problem here is that you did not mention the version of AutoCAD that you are using to help you verify its compatibility with your computer.
I assume that you are aware and you know the system specifications of your own computer. Visit AutoDesk — AutoCAD and look for the version that you think is compatible with your machine. You may also try uninstalling the application then check your computer for any possible errors. Use a disk utility application to check the system. After doing this, install AutoCAD again and then test it.
