Ascii menu generator for Mac OS
Hello techyv.com!
The type of ascii menu generator that I'am using is Magic ASCII Studio 2,2 with my Windows Vista laptop. Now I'am planning to buy a new Apple laptop. Its operating system is Mac. When I've downloaded the program, there is no specification of operating systems mentioned, So can I still use the same version of ascii menu generator on a Mac OS?
Answered By 30 points N/A #148916
Hi Leslie Joshuaa,
Thanks for raising the issue. I am afraid Magic ASCII Studio 2.2 or later version still does not support MAC. In their specification sheet they only mentioned about supporting Windows 98 and later version. But the good news is there are other ASCII converter you can use in your MAC. Please find the list below.
1. ASCII Converter 1.0 which can be downloaded from here.
2. Another software is Trapeze 2.0 which not only converts ASCII but also have functionality like converting PDF to RTF. Please download it from here.
3. Another interesting tool is ASCII Art 1.07 which converts images to text art. Download link is here.
You can download any one depending on your need.
Thanks & Regards,
DBD
