The application Finder.app can’t be opened. -10810
My Apple Mac has thrown an error message. The screenshot of the error message is as under.
After getting the error message, I have failed to launch any application. What should I do?
I tried all the possible sources to solve the problem but no result. If you have any idea for the issue, please help.
Thanks in advance.
-10810
Best Answer by Emil Onoon
Answered By 0 points N/A #191789
Hi Green Scott,
This problem seem to be closely associated with faults in the Lunch Service feature of OS X, regardless how drives are mounted, either through various ports such as USB or Firewire. Here are some step-by-step guides on how to deal with this problem:
Answered By 0 points N/A #191790
I will help you with Mac OS Finder app problem. This problem happens sometimes when you try to force quit the Finder app when it is doing something. You can deal with this problem by restarting your Mac or by repairing the startup disk. To repair, start from Mac OS X Install disk and repair.
