APPCRASH Error on Internet Explorer
I recently installed Internet Explorer 9 on my Windows 7 32-Bit OS. It was working perfectly fine at first but suddenly stop working correctly. I uninstalled it and try to reinstall IE8 but I am seeing an error stating, APPCRASH. What is this error and how to resolve this? Any help will be appreciated. Thank you.
Best Answer by Edmund Joseph
Answered By 0 points N/A #113295
Hi Paul Anderson,
I think IE 9 has not completed uninstall from your pc. To completely uninstall you can use the uninstall expert software from www.phazeddl.com. By this you can uninstall completely IE 9 from your PC.
Another option is that you can restore your computer at an earlier date and time. When your computer has worked fine.
Hope through this you can resolve this issue.
Regds
Jasbir Singh
Answered By 5 points N/A #113296
Hi there user:
APPCRASH is a serious error, a serious damage, and of course, a serious problem that you should resolve at its early state. Mostly it is caused by viruses and spywares, happens if you don’t have an antivirus or, you have one but did not update. You can’t tell when these pests could attack your system. Download the Windows 7 APPCRASH Fix right away. Below is the link where you can download it.
 https://www.slideshare.net/HelenDavid/how-to-fix-windows-7-app-crash-29107558
Thanks for your post.
Best regards,
