I have Windows XP installed and my 7 years kid accidently deleted some of my important file permanently. I want to ask, if someone know some recover deleted files freeware software? Any kind of help would be appreciated.
Anybody tell me some recover deleted files freeware software?
Hello there.
I use this site to recover deleted files, since I do a lot of mistakes while I do my work.
I suggest you look up this website, http://www.recover-deletedfiles.net/windows-7.html, which contains a lot of versions of the tool depending on your Windows.
From here i think that you can also get the free trial version, or you can buy the whole thing.
The tool is easy to work with, and should recover your files with not a single problem.
Regards.
Hello Dear,
Thanks for sharing your problem with us.
Dear data has more value than machine.
I am referring you to use a software for recovery of deleted or formatted data.
It will show you 100% positive result.
You should use Ontrack Easy Recovery Professional. It is very easy to use.
You can download it from this link.
http://download.cnet.com/archive/3000-2248_4-37386.html
I hope it will make you happy.
Thanks
